AAEON AEC-6910 BOXER S PC
Aloittaja X-mosh, 22.08.17 - klo:17:26
X-mosh
Myydään passiivijäähytteinen pienikokoinen pc.myydään ilman kovalevyä.
Speksit:
CPU                Intel  1.6GHz Celeron M Processor
System Memory    DDR SDRAM DIMM x 1, Max. 1 GB (tällä hetkellä sisällä taisi olla 500mb)
Expansion        PCI x 1 (optional 2), PCMCIA slot x 2
               VGA / Keyboard / Mouse    DB-15 VGA Connector, PS/2 Keyboard & Mouse
Ethernet             10/100Base-TX RJ-45 connector x 1
SSD                Type II CompactFlash™ slot x 1
Hard Disk Storage    2.5" Slim Hard Disk Drive Bay
Serial Port            RS-232 x 4
Audio                    Mic-in / Line-in / Line-out , by extension cable
USB                USB 2.0 port x 4
Parallel Port        Print port x 1
System Control    Power on / off switch x 1, Reset button x 1
LED Indicator        Power LED x 1, Hard Disk Drive active LED x 1
Watchdog Timer    Generates a time-out system reset, setting via software
Power Supply        1. DC Input -- Internal DC-DC Converter(Default)
Input voltage:        9V DC ~ 30V DC
Mechanical and Environmental
Construction    Rugged Aluminum Alloy chassis
Color        Mustard
Mounting        Wall-mount
Dimension    214mm (W) x 94.75mm (H) x 237.8mm (D) - 1 PCI
           214mm (W) x 117.5mm (H) x 237.8mm (D) - 2 PCI
Carton Dimension    336mm x 294mm x 260mm
Net Weight    5.63kg - 1 PCI
           6.21kg - 2 PCI
Operation Temperature    5°F ~ 131°F (-15°C ~ 55°C)(P-M 1.6GHz,CFD)
                   5°F ~ 122°F (-15°C ~ 50°C)( P-M 1.6GHz,Automotive HDD)
                   5°F ~ 113°F (-15°C ~ 45°C)( P-M 1.6GHz,Normal HDD)
                   Operation Humidity    5~95%@40°C, non-condensing
Vibration                5 grms / 5 ~ 500Hz / random operation(CFD)
                   1 grms / 5 ~ 500Hz / random operation(Internal Hard Disk Drive active Module)
Shock                50 g peak acceleration(11 msec. duration)(CFD)
                   20 g peak acceleration(11 msec. duration) (HDD Module)
EMC                    CE/FCC class B
Katso koko ilmoitus
