M: Askelmoottoriohjaimia 5A
Aloittaja Teppo Leinonen, 19.02.15 - klo:19:58
Teppo Leinonen
Myydään askelmoottoriohjaimia:
HY-DIV268N-5A Single Axis 5A CNC Stepper Driver For CNC Milling Machine DIY Max 50V
Description:
- HY-DIV268N-5A subdivision-type two-phase hybrid stepping motor drive using DC 12 ~ 48V power supply, suitable for drive
Two-phase hybrid stepping motor dynamic voltage 12 to 48V, the current is less than 5A outer diameter of 35 to 86 mm. This drive using the drive's current loop subdivision control, the motor torque ripple is very small, low-speed running is very smooth, almost no vibration and noise. High-speed torque is much higher than other two-phase drive, high positioning accuracy. Widely used in the engraving machine, CNC machine tools, packaging machinery and other high resolution requirements on the device.
The main features
- average current control, two-phase sinusoidal current drive output
- DC 12 ~ 48V power supply, the internal integration of 12V and 5V regulator
- optically isolated signal input / output
- overvoltage, undervoltage, overcurrent, and white short-circuit protection
- Input voltage DC 12 ~ 48V input
- The input current of 1 to 5 amps, select the drive a stepper motor.
- Output current of 0.2A ~ 5A
- Temperature Operating Temperature -10 to 45 ?; Storage temperature -40 ? to 70 ?
- Humidity not condensing, not drops
- Gas prohibit combustible gas and conductive dust
- Weight 200 grams
Katso koko ilmoitus
En mä kaikkia ajatuksiani toteuta....
...mutta niitä ajatuksia vaan tulee ja tulee...
