M: CNC osat
Aloittaja longgo, 27.01.13 - klo:14:14
longgo
Hi,
Because of update of my project i wish to offer some parts for sale:
6 pcs of SHF25 - Linear Rod Rail Shaft Support -
new, never used - price: 25e without delivery
3pcs of  5 to 10mm  CNC Flexible  motor shaft coupler (new)
new, never used - price: 8e without delivery SOLD
from that machine:
for sale is:
4pcs of  5 to 6mm  CNC Flexible  motor shaft coupler (only one is new, the other 3 are still on machine)
new&used - price: 12e without delivery
3 x stepper , nema 17
Type:Stepper Nema 17
Angle step:1.8°
Voltage: 3.4V
Rate current:1.7A
Phase resistance: 2 oM
Phase inductance: 3 mH
Holding torque: 4000 g.sm
Lead wires: 4
Rotor inertia: 54 g.cm2
Detent torque: 220 g.cm
Motor weight: 0.3 kg
Motor lenght: 40mm
Motor width: 42mm
used - price: 50e without delivery
CNC to PC breakboard - 5axis, limits, joystick control and more. Including CD with documents and LPT cable(mini USB not included)
never used - price: 14e SOLD
Controller board:
My design, prepared to carry 3 x A4983 Stepper Motor Driver Carrier with Voltage Regulators Pololu(http://www.pololu.com/catalog/product/1202/resources) - MAX 2A per phase 1:1 to 1:128 step , adjusted via jumper configuration. Input STEP,DIR,ENABLE from break board.
!!! That 3 A4983 controllers from the picture are NOT included, only the board !!!
that is the second one and it never been used, but tested and work perfect - price: 22e without delivery
contact only on mail please: kovachev.svetoslav (at) gmail (*) com
Grinder831
Jeps ! Tavarat liikkuu Tältä Myyjältä-ostajalle perille asti  :) 5mmX10mm couplingit saivat uuden omistajan  ;) Pääsee asentaa moottoreita akseleihin kiinni  :D
